C farmall
bm3501466
11-09-2006 15:01:12
Is it true that a 544 diesel motor will bolt right into a c farmall or is it just a 504 motor? Are there any differences between the bell housings on the A, B,C, H, and M"s? What other motors will fit in the C even if you have to make the frame rails longer?
Curious
11-09-2006 18:28:24
 Re: C farmall in reply to bm3501466, 11-09-2006 15:01:12
A C-153 out of a combine will fit in a C with out to much trouble you just need to find a poliet bearing and a different water neck off the head. I have one from a 140 and everything lines up pretty good.
Wardner
11-09-2006 17:18:06
I like the question and would like to see more of these. This subject is the reason why I have parts books of tractors that I do not own. For instance, I have a 656 book but I doubt if I will ever own the tractor. I assume there must be alot of 300, 330, 340, 350, 460, 504, 606, and others that could use parts from that tractor. The parts could be direct replacements or slightly different to improve operating characteristics for a special application. I did a bunch of gear swapping in a SMTA and now have a tractor with a top speed of 11 mph. 1st gear, low range is around .5 mph at rated rpm.
Getting back to your question, I doubt if a 504 motor(C153) will fit easily into a C. Although the motor uses many of the parts from a C and SC parts book, it is cast with a flange that bolts up to the H derived tractors.
teddy52food
11-09-2006 17:12:28
The C doesn't have frame rails.
