Farmall 100 restoration
bigblockdude402
11-09-2006 16:14:42
I have started a restoration on my deceased grandad's farmall 100. Is there anything I need to know? What about lubrication specs? Should I consider a power upgrade? Do I need it? Should I keep the cultivators? Do they make the tractor more unique? Any info is appreciated!
Hugh MacKay
11-09-2006 20:19:40
 Re: Farmall 100 restoration in reply to bigblockdude402, 11-09-2006 16:14:42
Restore it to original specs, these little tractos run out of traction long before they run out of power. Get the manual, there are lubrication points you will miss without.
bigblockdude402
11-10-2006 15:53:35
 Re: Farmall 100 restoration in reply to Hugh MacKay, 11-09-2006 20:19:40
Thanks
daniel h.
11-09-2006 17:25:35
First thin you need is an owner's manual. It contains more information than you can imagine. Try Binder Books for that. I would keep the cultivators, they are great for a garden.
City-boy McCoy
11-09-2006 17:52:30
 Re: Farmall 100 restoration in reply to daniel h., 11-09-2006 17:25:35
In addition to what Daniel said, you don't need a power upgrade. These little 100's are more than twice as powerful as a Cub, and only about 25% larger machines. They have plenty of power for their size and weight. If you need more power, then you need a bigger tractor, in my opinion.
mike
bigblockdude402
11-10-2006 15:54:55
 Re: Farmall 100 restoration in reply to City-boy McCoy, 11-09-2006 17:52:30
Thanks fellows!
