That A Farmall Sweeper I'm looking at: more info..
DennisT
11-09-2006 17:47:03
The Farmall Model A industrial with the street sweeper attachment was the subject of my road trip again today. Found the serial number which appears to be: 1AA 13099. I found that to be 1940 in the IH s/n list. The 1AA part was hard to see, but that's what it looks like.
The add-on non-working hydraulic system had a tag when I dug around: "Blackhawk Jack, Model BM1," - anyone ever hear of that?
Not sure if this info will spark any more feedback on this tractor, but that's the story so far.
Dennis
Dave Sherburne NY
11-10-2006 14:42:49
 Re: That A Farmall Sweeper I'm looking at: more in in reply to DennisT, 11-09-2006 17:47:03
Does that blackhawk jack look like a regular hydraulic jack with a starter motor sticking out the
side, I have one that looks like it is supposed to be an electric snow plow lift. I think its a 6 volt
because It spins real fast when I hook it to my 12
volt tractor.
Janicholson
11-10-2006 06:24:13
As Bruce indicates, I believe I was correct in pointing to a hand pumped hydraulic system on the top of the Dif case. I'd still buy it. JimN
Bruce Wa.
11-10-2006 05:50:03
read my reply to your previous post.
Jim Becker
11-10-2006 05:38:27
Is there any chance you missed one digit on the serial number? A couple things that showed in the pictures you posted earlier suggest a later tractor, like maybe in the 130K serial range rather than 13K. 130K would be 1945. The IAA prefix is correct for an industrial A.
City-Boy McCoy
11-09-2006 18:03:45
Blackhawk made a lot of manually operated hydraulic shop jacks, like what a small repair shop uses to jack up a car today. I'm sure they made other things also.
Blackhawk was a division of some major U.S. corporation, maybe Stewart-Warner, or some similar company - although SW does not sound just right. I think Blackhawk was out of Chicago.
mike
