SMTA various rods?
Atvman
11-09-2006 18:19:17
I have a smta that needs a choke rod, hydraulic control rod, and belt pulley control rod. I saw each of these on ebay off an H. Will any of these rods off an H fit a SMTA, or can they be slightly modified to fit?
Wardner
11-09-2006 19:47:22
 Re: SMTA various rods? in reply to Atvman, 11-09-2006 18:19:17
I wouldn't hesitate to make any of the rods you listed if I had a pattern to go by. I do, of course, so it is easy for me to say.
I think Home Depot will have the stock. A propane or MAPP gas torch will give you enough heat to make accurate bends on the small diameter stock. The hydraulic rod will require a bit of welding. I think the small protrusion that locks the rod to the rear was attached with a resistance weld. It also needs a thread, a couple of nuts, and a flatbar clip bent to a 90 degree angle
If this isn't something you wish to pursue, just keep watchng eBay. Those parts will come up. The choke rod is probably universal to all M's. The other two will need to come off a SM with live hydraulics.
randy hall
11-09-2006 18:46:42
with enough work anything can be made to fit but none of these parts from an h will work as is.
