Farmall A Pulley
LA-Man
11-10-2006 05:27:36
Would one of you Red guys tell this Green guy the best way to remove the crankshaft pulley on an "A"? Also, how rare is an Industrial "A" complete with yellow paint? Thanks.
Georgia Boy
11-10-2006 10:51:05
 Re: Farmall A Pulley in reply to LA-Man, 11-10-2006 05:27:36
I had to purchase a heavy duty two jaw OTC puller and a large bearing splitter. Then I used some heat, also. The important thing to remember is to get the puller completely behind the pulley neck, as close to the shaft as possible, or you will break off parts of the flange.
El Toro
11-10-2006 05:54:45
third party image
You need a puller like this. It was designed for the Cub, but could be modified for your A using a hydraulic jack or ram. Hal
