D407 and D414
Nates90
11-10-2006 06:34:19
Hi guys, I was wondering what the difference was in the D407 and D414 engine on the outside, so i can tell what engine i have. I was also wondering when they say DT414, was the T for turbo.....Thanks a bunch guys.
cb,ont,ca
11-10-2006 17:43:18
 Re: D407 and D414 in reply to Nates90, 11-10-2006 06:34:19
The d414 is a newer wet sleeve moter used in the 66, 86 series tractors ,
The D407 is a dry sleeve motor used in the older 806 tractors. Dont know of many d414 more were the turbo Dt414
used in the 1066,1086 and 88 series tractors.
K.B.-826
11-10-2006 18:48:12
 Re: D407 and D414 in reply to cb,ont,ca, 11-10-2006 17:43:18
966 has a non-turbo 414.
Nates90
11-10-2006 10:31:16
I was wondering if the Bosch pump that you are talking about is a rotary pump or is a P-series straigh line pump. Reasoning, i know how to turn up the pump on the bosch ones, just like in a B-series cummins. Has anyone turned up a diesel in a combine before....hehe....
-Nate-
chuck46
11-10-2006 08:22:00
Hi, The 407 will have 2 oil filters inside canisters on the left rear, and a roosimaster pump on the front right. The 414 will have spin on oil filters at the right rear, and a bosch pump left front. Good luck, Chuck
Wardner
11-10-2006 07:24:46
DT = diesel turbo
DTI = diesel turbo intercooled
