year for McCormick Deering 1020
Jake 10 20
11-10-2006 08:36:03
I can't read the serial number, the seat curves way down in the back. The exhaust comes from under the fuel tank, not out the side. Is there anything else I can look for to see what year it is?
Thanks for you help
russ hamm
11-10-2006 15:46:49
 Re: year for McCormick Deering 1020 in reply to Jake 10 20, 11-10-2006 08:36:03
check the left side engine block at the front near the cylinder head. that number should work to date it.
Sloroll
11-10-2006 08:55:53
YOu can look under the tractor's rear and the date the rear end was made should be in the casting.
neblinc
11-10-2006 08:50:55
Are you saying you found the serial number tag but can't read it?
If so, take a piece of paper and lay it over the tag, rub a pencil lightly over the paper and you should be able to get your numbers.
Randy
