Farmall Auxilary valve for a M
M clunker
11-12-2006 01:44:19
Hi guys ,Does anyone know what the nut ontop of the cover if for?I think it is the adjustment for neutral/return position.does it need to be adjusted and if so how ?The nut on mine just barely start on to the threads sticking through is this right. What will happen if it is overtighten? thanks
JWalton
11-12-2006 09:48:24
 Re: Farmall Auxilary valve for a M in reply to M clunker, 11-12-2006 01:44:19
If you take the three bolts out that hold the top cover on you should be able to pull the top and spool out together. on the underside of the top are two nuts with a notch in them, this fits into a raised area on the underside of the top. The nuts adjust the spools ability to center. You should be able check the adjustment by removing the hoses and looking in each port to check the centering of the spool.
