transmission brake
Larry B. -1466
11-12-2006 06:44:28
I have a 1486 that has the TA fixed solid on the high side and it is hard to shift the speed leaver, the 1 2 3 4 range. The high low reverse works preaty good but have to put in neutral to be able to shift the speed trans or you can"t change gears,won"t release. Was told that the transmission brake is the problem. Any help appricated
Aces
11-12-2006 08:51:10
 Re: transmission brake in reply to Larry B. -1466, 11-12-2006 06:44:28
Larry the transmission brake would be a problem for both transmissions. Don't know how the TA is locked solid that could be some problem but should be problem for both.
