Super A Hydraulic Pump
Harold H
11-13-2006 08:23:18
Will a hydraulic pump from a Super A fit on an A engine? If there is a serial number break, after what serial number A will the timing gears accept the Super A pump, if there are late A engines that will accept pump mounting.
Thanks,
Harold H
Hugh MacKay
11-13-2006 08:33:25
 Re: Super A Hydraulic Pump in reply to Harold H, 11-13-2006 08:23:18
Harold: None of the Farmall A or B blocks were drilled for mounting the pump. Change came at serial number 250000, after that they were all Supers.
gene bender
11-14-2006 04:01:52
 Re: Super A Hydraulic Pump in reply to Hugh MacKay, 11-13-2006 08:33:25
You mite haave a later A that used the SA block. a few Bs had the blocks cast for the pump also. They started casting the blocks for the pumps way before production stopped on the A and B tractors. I have one that was cast in FEBURARY 47 long before production stopped on A and B models.
Jim Becker
11-14-2006 18:56:11
 Re: Super A Hydraulic Pump in reply to gene bender, 11-14-2006 04:01:52
And I have a B from September '47 with the original block and no place for a pump. The earlier ones with a pump were probably a few that were run as samples.
