130 Hydaulic Screen
chad504
11-13-2006 09:19:28
I know that the left side of the reservoir has a filter screen, can I remove and clean it, without losing a large amount of fluid, or will this drain the fluid (like removing a drain plug) in the process?
scotty
11-13-2006 09:23:30
 Re: 130 Hydaulic Screen in reply to chad504, 11-13-2006 09:19:28
Hi Chad, You need to drain the hydraulic unit out and then remove the screen to clean it. You will also need a new gasket.
scotty
