H rear wheel wobble
dakotaclassic
11-13-2006 15:08:17
ok had a big poping noise now when im in reverse the left wheel semes to flex a bit on the shaft (the whole shaft moves) and when the brake is applied to the left side it makes a realy bad pop grind noise near the axle area. did it blow bearings by the pig? anyone done this and how bad to fix$$$? anyone wana buy a running H with live hydrolics and fenders?
GordoSD
11-14-2006 08:28:34
 Re: H rear wheel wobble in reply to dakotaclassic, 11-13-2006 15:08:17
Not a hard fix at all. Sounds like you caught the inner bearing failure quickly. Remove PTO and drain the tranny, probe around in there with a magnet on a rod or shaft. Support the bull gear exactly where it is with a piece of cut to fit wood wedge. Pull the axle and replace the bearing/bearings as needed. Or if you are not too far from Mitchell SD I can help or buy the thing.
Gordo
riverbend
11-13-2006 19:44:25
I'll give you $300 for it if you bring it over.
The biggest problem is that the shards of the bearing fell inside the rearend. the big stuff will settle to the bottom, but the little stuff will get circulated through the rest of the bearings.
Like anything on an H, it is an easy repair. You just have to remove the top cover to make sure that everything is clean. I spent about $500 to replace all the bearings in the transmission on my H.
Greg
