Super M 9 speed?
D. Shafer
11-13-2006 15:30:21
Did M&W make a 9 speed for the Super M? If so, was the 2nd through 4th gear speed (on the low side)the same as the original Super M? Thanks.
D Slater
11-13-2006 18:24:52
 Re: Super M 9 speed? in reply to D. Shafer, 11-13-2006 15:30:21
Yes they made it and No, M&W SM fourth speed gears are slower than IH SM fourth. If I remember correct one tooth bigger on 4&5 slider and one tooth smaller on fourth drive gear, 1 through 3 the same. Have numbers here somewhere I could double check. Had 2 at one time but like the regular M gear spread better with 9 speed. Had a SM hiesler 9 speed but was never inside it to check gear counts.
D Slater
11-13-2006 19:14:35
 Re: Super M 9 speed? in reply to D Slater, 11-13-2006 18:24:52
My memory was off, found my notes, on standard SM the 4th drive gear is 33 and driven 30 in a M&W they are reversed. 30 drive and 33 driven. Think M&W used the same 4 and 5 sliding gear in some W6 9 speeds.
Wardner
11-13-2006 17:58:35
Yes, M&W made 9 speed conversions for SM but not SMTA.
The original speeds are retained on the low side. The countershaft is speeded up and 1st thru 4th are something like 100% quicker in high range.
r4etired
11-13-2006 17:57:28
I know of 3 manufactures that made 9 speeds, Heisler, M&W, Behlen. Don't think any of them made one for the supers as they had a fast 4th. They were real common in our area in M's Three of my M's have them, I have looked for years for one for an H, now in the last 2 months I have bought two of them.
