sure need a little advice
tn terry t
11-13-2006 16:50:07
hello its me again im having a little trouble with finding a cam gear for a 300 i keep coming up with the h gear 6664d everyone is selling that number for the 300 367325r1 so is it that much different in the two gears ? i have every thing except the cam gear to put live hydraulics on one of my h tractors thanks for everything terry t
chuck46
11-13-2006 19:56:11
 Re: sure need a little advice in reply to tn terry t, 11-13-2006 16:50:07
Hi, I never replaced the gear on my 41 H, The pump has been on it for more than 30 years, and has had many thousand hours of use. Keep the one you got. Good Luck, Chuck
D Slater
11-13-2006 18:42:08
Look for a 6664 DA or DB. 6664 DB is the last one used in 300 and 350. Don't know about 367325 R1 number unless its a later replacement from IH. Never found one in a tractor.
El Toro
11-13-2006 18:35:51
Try Walts tractor parts at 1-888-414-4043. He has a new gear for $92.00 for the 300.Hal
NO tools
11-13-2006 18:34:12
THE 367325r1 gears are getting few and far between.
the reason is back in the day that them tractors were being used hard they would shake the nut lose on cam shaft and distroy the gear.
THE 6664d is what most people used from the h parts list to replace the 367325r1.
What you find alot of is the h camshaft and gear has been installed.
Basicly the only difference between the two gears is the part number.
the cams are just a little different on the lobs.
tn terry t
11-13-2006 19:36:49
 Re: sure need a little advice in reply to NO tools, 11-13-2006 18:34:12
thanks so the 6664d gear that i have in my h will work ok with the hydraulic pump from a 300 right?
