brakes on M
HENRY E NC
11-14-2006 08:26:42
What is the purpose of adjusting the brake compression spring. Am replacing brake bands and would like to know how to adjust the compression springs properly
Michael Soldan
11-14-2006 15:24:10
 Re: brakes on M in reply to HENRY E NC, 11-14-2006 08:26:42
You want the brakes to be equal on each side, so the left and right pedal have the same pull on the brake band and both rear wheels brake evenly, the clevis on each side gives you this adjustment
Yugrotcart
11-14-2006 13:52:27
I would assume that you are talking about the turnbuckle like adjusters that have a spring in them.
Paul
HENRY E NC
11-14-2006 19:39:34
 Re: brakes on M in reply to Yugrotcart, 11-14-2006 13:52:27
Yes, that is what I am talking about and I adjusted them to apply equal pressure on each brake pedal as Mike Soldan indicated and that is what I wanted to know. Thanks for the info and replies
