Where Are There Governor Parts?????????
FarmallBob
11-14-2006 16:21:38
Where can I find new governor parts for my Farmall Super C????? I have on the Internet tried Valu-Bult, Case/International, and no results. Any help will be much appreciated. Thank you.
Bob
Brownie 45
11-16-2006 12:57:53
 Re: Where Are There Governor Parts????????? in reply to FarmallBob, 11-14-2006 16:21:38
Hi. Checked at IH, & everything except the speed change lever shaft seal retainer is still available. Do you have a dealer close by? If not, let me know & I'll order for you.
Brownie 45
11-16-2006 05:30:39
I'll do more research at IH on these parts. Finally found the needle roller brg. box & # is45753-D. For some reason or other, condensation tended to collect in the governor & made a lot of rust in brgs & other parts. We had to just about completely rebuild the A governor several years ago because of rust seizure. Enough for now.
Gary_N_WV
11-14-2006 18:18:21
Talk to Bermuda Ken who frequents this forum.
Brownie 45
11-14-2006 18:08:04
Small needle bearings were available at IH. Could get numbers in the morning, but someone on here will no doubt have them before then. What parts do you need?
FarmallBob
11-16-2006 01:43:46
 Re: Where Are There Governor Parts????????? in reply to Brownie 45 , 11-14-2006 18:08:04
Hi Brownie 45,
I can not locate the *governor speed change lever shaft seal retainer
*governor spring lever washers
*governor speed change lever shaft oil seal
*governor bumper spring
*governor shaft bumper spring
*governor shaft bumper spring pin
*governor shaft stop pin
I would go to a hardware store to purchase most of this, but they are so badly wore that they can't be recognized. Thanks! I appreciate your help.
Bob
