Farmall 200 value?
Corey Harder
11-14-2006 17:03:35
I bought a farmall 200 narrow front last fall for $3000. It has been repainted but nothing mechanical was done to it except for new rubber. It runs fine smokes a little when first started. I had to replace hydraulic hoses,generator and front wheel bearings. I was wondering what it might be worth,and why there ar so few of them.
City-Boy McCoy
11-14-2006 17:56:01
 Re: Farmall 200 value? in reply to Corey Harder, 11-14-2006 17:03:35
The C's, Super C's, 200's and 230's are nice tractors, but you "stepped up to the plate" when you paid $3,000 for one that smokes and is not showroom new - at least in my part of the world. I would say $1400 to $1800 is more in the range of current market value. They are a handy size machine, though.
mike
CNKS
11-14-2006 17:27:59
$3000 was on the high end, depending on the location. If it smokes it is worth less than $3000. It depends on how bad someone wants it. About 15000 230's were built. A 200 is basically a Super C with different sheet metal, there were nearly 98000 Super C's built, and nearly 80000 C's built. The 230, which is basically a red and white 200, numbered about 7100, so there were over 200000 of that type tractor built. There is little difference between these 4 tractors, except for fast hitch which appeared on the Super C and increased HP. That's a bunch, it had to end sometime to keep up with the competition.
