Farmall M battery going dead.
Geb
11-15-2006 17:47:14
Thanks to all for the help I got my M started replaced the coil, pionts, cap rotor, etc, now the battery is drawing down , something is causing this and I do not know what. Any help is greatly appreciated.
Thanks Geb
gene bender
11-18-2006 05:27:43
 Re: Farmall M battery going dead. in reply to Geb, 11-15-2006 17:47:14
What does the hydrometer read are all the cells close if one cell is weak it realy reduces the crank power.
kejab21
11-16-2006 17:50:08
adjusting spring tention in the VR worked on mine
souNdguy
11-16-2006 07:02:40
A circuit systems polarize by jumpering ARM (gen) to BAT momentarilly.
Soundguy
IowaFarmall
11-15-2006 18:05:18
If you have one, check the regulator to be sure it is not sticking closed when the tractor is shut off.
old
11-15-2006 17:56:16
Is it 6 volts or 12 volts?? Does ithave a genny or an alternator?? Common problem for that is a chargeing system problem but with out more info hard to say
Geb
11-15-2006 18:04:43
 Re: Farmall M battery going dead. in reply to old, 11-15-2006 17:56:16
It is 6 volt, and a genny, is there a way to test the genny to see if it is working properly
old
11-15-2006 18:11:26
 Re: Farmall M battery going dead. in reply to Geb, 11-15-2006 18:04:43
You most likely have a set of points in the VR stuck and causeing you the problem. Some times you can open up the V.R and file the points, or just replace the V.R. and polerize the system
Geb
11-15-2006 18:41:58
 Re: Farmall M battery going dead. Polarize?? in reply to old, 11-15-2006 18:11:26
It;s a brand new V R, but I'll try that, how do you polarize??
Janicholson
11-15-2006 18:57:52
 Re: Farmall M battery going dead. Polarize?? in reply to Geb, 11-15-2006 18:41:58
Check out the John T info. It is complete and answers many questions. JimN
souNdguy
11-16-2006 06:58:53
 Re: Farmall M battery going dead. Polarize?? in reply to Janicholson, 11-15-2006 18:57:52
A circuit systems by jumpering ARM to bat
Soundguy
Janicholson
11-15-2006 18:00:51
Look in the archives (search for) John T my cub doesn't seem to be charging. His post is what you need. JimN
