H crank
Calhoun
11-15-2006 18:37:51
I recently pulled the engine down on an H I just bought.After I pulled the pan I knew the crank was shot just by looking at the #1 rod journal,it had spun the bearing and I guess the guy I got it from could'nt here the knock.I took it to the machine shop just too find out it was worn .78.Anybody got a crank for sale,I've been watching the classifieds with no luck.Thanks,Eric in Ky
El Toro
11-16-2006 06:10:36
 Re: H crank in reply to Calhoun, 11-15-2006 18:37:51
Try Walts tractor parts at 1-888-414-4043. He has a reground shaft for $160.00. You can get new insert bearings from your local auto machine shop.
gene bender
11-16-2006 04:04:59
You can get one with new bearings reground and ready to go for around 350 better than buying a used one that may be just as bad as the one you have now. if interested send e-mail
Dave S.
11-15-2006 21:54:12
Try Mike at Steel Wheel Ranch Ph 785-548-7437.
Mike CA
11-16-2006 00:15:06
 Re: H crank in reply to tn terry t, 11-15-2006 19:54:49
$350 seems excessive for a crank!!
RustyFarmall
11-16-2006 04:41:01
 Re: H crank in reply to Mike CA, 11-16-2006 00:15:06
$350 for a crankshaft in excellent condition with new bearings is pretty reasonable.
gene bender
11-16-2006 04:16:28
Bearings will run 150 grinding the crank another maybe 100 and his is shot so he needs a good core or else spend a bundle building his up. I seen pics of what you bought and just wait till you get done a nece H with good paint is cheap for 2000 compared to what it is going to cost. good luck and have fun
