560 torque clutch
petenev
11-15-2006 19:09:06
i bought a clutch off ebay for a 560 diesel ta when it arrived it was completely differant from my old one it looked the same in the pictures in fact the dia. is 6 or 7 inches compared to 10 or 11 inches my question is did they make more than one style? and the clutch in a 460 sould be the same as a 560? thanks for any help pete
petenev
11-15-2006 20:10:30
 Re: 560 torque clutch in reply to petenev, 11-15-2006 19:09:06
maybe i do not understand how they work or fit together the main clutch goes into the flywheel where does the ta clutch mount thanks pete
Nat 2
11-16-2006 05:37:28
 Re: 560 torque clutch in reply to petenev, 11-15-2006 20:10:30
The TA clutch mounts on the TA, which is in the TA housing between the main clutch and the transmission.
A TA clutch by itself is relatively worthless. I've never heard of a TA that failed because of the clutch. It's usually the ramp and roller assembly, and at that point it's usually better to just install a complete new TA assembly so you don't have to tear the tractor all apart again. A new TA assembly includes the TA clutch AFAIK.
Aces
11-15-2006 19:49:49
The TA clutch is the same for all the machanical TA's the main clutch is different.
K.B.-826
11-15-2006 19:48:15
There are two clutches in a 560 when it is equipped with a TA, the engine clutch and the TA clutch. Sounds like you got the clutch that goes in the TA. Those are 7" in diameter if I remember correctly, should be the same size for a 460 or 560. Sounds like you were wanting to buy a main engine clutch. Those are 12" in diameter for the 560. I'm sure the 460 has a smaller engine clutch.
