Farmall AV and a power unit
All
11-16-2006 08:49:38
Hello I have recently bought a AV. The engine has a craked block. I also have a four cylinder power unit that is in running condition. Can I switch these two motors without any problem? Is the power unit worth anything by itself? How long of a job would you estimate this to be? Thank you
Red Dave
11-16-2006 09:58:05
 Re: Farmall AV and a power unit in reply to All, 11-16-2006 08:49:38
I think it could be done if the power unit is the one that uses the engine that is the same as the one used on Farmall A's & B's.
Some of the issues that come to mind are:
Use the flywheel from the AV, you'll need the clutch surface and the ring gear.
You will have to either use the crankshaft from the AV, or have a hole drilled into it for the pilot bearing.
that's just the things I can think of offhand
