h and m starting crank storage
glennster
11-16-2006 08:55:11
where was the origionl location on these rascals that the starting crank was stored? my b and cub have clips on the operator platform. my w-9 has a spot on the right side of the tractor just foreward of the bellhousing. my 3 m's, my h, and my super m all have the starting cranks stored on the wall above the workbench. i must have brain damage, but i cant remember ever seeing one with the crank stored on it other than sliding around under the seat.
Dan Bear Kelley
11-21-2006 14:54:21
 Shop Absorber in reply to glennster, 11-16-2006 08:55:11
No, the shop absorber is the gizmo that causes all your stuff to expand to fill a new and bigger shop. It absorbs the extra space. :-)
chuck46
11-17-2006 08:41:01
 Re: h and m starting crank storage in reply to glennster, 11-16-2006 08:55:11
Hi, My Dad bought a new H in 42 , couldn't get starter and lights. On the left side the crank slips behind the pulley housing and in front of the gas tank support. In 64 years it has never been lost. Good Luck, Chuck
NDS
11-16-2006 16:17:15
In my opinion crank should be hung on back wall of tractor shed and left there that is where we always stored ours. Have seen to many injurys from kick back and yes they will all kick sooner or later a little moisture in distirutor cap can cause erractic firing for one thing.
DollorBill
11-16-2006 15:13:21
If you have a drawbar the handle will slip down into the top of the Square Tubing and rest next to the fender.
randy hall
11-16-2006 11:45:24
the early manuals show the crank in the seat toolbox. it will also hang between the frame rail and the block real nice.
williamf
11-16-2006 11:13:58
I snake mine in between the rear tank support and the steering post. It stays put pretty well. I use it every time I shut off the engine. (Got to replace that ring gear one day.) It's a little tricky getting it out on the odd time that I don't set the brakes. And when I do set the brakes I'm always conscious that I might hit the latch with the handle. Good luck, Wm
iowafarmall
11-16-2006 09:17:54
I keep mine between the rear gas tank support and the belt pully.
CNKS
11-16-2006 09:07:41
Ours had the deluxe seat with the shop absorber, it fit perfectly when slid under the center of the seat frame. Others store them inside the frame rail. I don't think there was a specific place.
CNKS
11-16-2006 09:09:27
 Re: h and m starting crank storage in reply to CNKS, 11-16-2006 09:07:41
Shock -- I have no clue what a "shop absorber" is, might come in handy with the wind we have, though.
little john
11-16-2006 09:39:51
 Re: h and m starting crank storage in reply to CNKS, 11-16-2006 09:09:27
CNKS, I was thinking a shop absorber what the thing that takes my tools and hides them somewhere.
RustyFarmall
11-16-2006 10:03:38
 Re: h and m starting crank storage in reply to little john, 11-16-2006 09:39:51
I thought it was the workbench that hides all those tools? Not sure what a shop absorber is, but if anyone figures it out, let me know, I might need one.
glennster
11-16-2006 10:18:04
 Re: h and m starting crank storage in reply to RustyFarmall, 11-16-2006 10:03:38
i gotta git me one of them shop absorbers for the next time i trip over an open 5 gal bucket of used 90wt gear oil!!!!
john cub owner
11-16-2006 20:12:51
 Re: h and m starting crank storage in reply to glennster, 11-16-2006 10:18:04
They can be stored on the right hand side rail, by sticking the handle down beside the oil filter housing, and letting the bend extend between frame and engine.
