Gas Tank Plumbing
Jimer
11-16-2006 18:24:25
Still trying to get a shut off valve on the gas tank of my 300u. Seems I will have some plumbing involved. My question is: Should I use rigid copper and solder fittings on the end or is galvanized steel OK?
Janicholson-
11-16-2006 20:38:57
 Re: Gas Tank Plumbing in reply to Jimer, 11-16-2006 18:24:25
Steel line. I believe the use of plastic, and most rubber fuel lines is not a good idea on a gravity feed fuel system. Production vehicles use rubber only where its failure will result in an air leak, not a fuel dump. (some may do this, but I cannot think of one) Stainless Steel lines are best, regular steel next best. JimN
504-1
11-16-2006 19:05:44
Steel brake line works great.
