Order Farmall Cub Parts Online
Cub hydraulic repair
banjo
11-17-2006 12:32:33
I've been over on the cub forum and received some help. But I'll run it past ya'll.
I took the block off and have it tore down and new 0-rings installed where i removed old ones.But i have 1 left over and connot find any place it could go. Plus i do not seem to have a releif valve or screen(cannot find where one was supposed to be).And the orifice screen seems to be MIA.
Thee are the 0-rings i have replaced. 2-acuator seal ring, 2-piston seal rings, 1- piston head seal ring, 1- regulator valve seat, 1- regulator valve piston seal ring,1- control valve seal ring. My connecting rod yoke has a tapperd shaft so it did not have an 0-ring there but i still have 1 left for something else that i cant figure out.
Did some of the cubs not have the releif valve plug and screen? there are no threaded holes under the bottom cover just the 3 allen head plugs.Thanks
Brett Chesshir
11-20-2006 08:36:03
 Re: Cub hydraulic repair in reply to banjo, 11-17-2006 12:32:33
I just did the rebuild on my 47 SA, I had lots of O rings left over, and some paper gaskets, my kit deffinately covered more than my tractor, I don't know anything about cubs but maybe 1 kit covers more than one
banjo
11-17-2006 12:35:58
One more thing. It has the 351 casting and the 02 suffix pump.
