Farmall A Head Gasket Sealer
Estle Cloud
11-17-2006 13:07:01
My new head gasket is labeled "Sealer/Retorque Required". I have never seen this instruction on a head gasket before. I know the head studs are to be retorqued with a hot engine, but the sealer is the question. What kind of sealer do I need, is it only applied in certain areas, or is the instruction actually sealer or retorque required? Any help will be appreciated.
Red Dave
11-17-2006 15:09:43
 Re: Farmall A Head Gasket Sealer in reply to Estle Cloud, 11-17-2006 13:07:01
It means sealer and retorque. I use a spray copper gasket sealer by Permatex that is made for high heat & pressure such as head gaskets.
Just spray it on both sides of the gasket & let it dry a little.
Estle Cloud
11-17-2006 15:18:21
 Re: Farmall A Head Gasket Sealer in reply to Red Dave, 11-17-2006 15:09:43
Thanks for the information. I have installed head gaskets in cars and trucks as well as other make tractors, but that was the first time to encounter this inbstruction.
