Wear ring, front wheel Super A
Hendrik
11-18-2006 13:32:25
Ordered overhaul sets for front wheels of my Super A at IH dealer. The wear ring (part number 49117D) is the thin sleeve like part on which the front wheel oil seal rides. The old one, nearly worn through, had a tight press fit in the wheel hub. The new wear ring has approximately 0.01 inch radial play and is really loose. Will it work if I glue the ring in place? Any and all help appreciated.
Hendrik.
Janicholson
11-18-2006 16:00:43
 Re: Wear ring, front wheel Super A in reply to Hendrik, 11-18-2006 13:32:25
No .010" is wide enough to play cards through, it is the wrong part. It will cause premature seal wear and grief. Unless there is a problem with the spindle, it should be a medium press fit. JimN
