400 Torque Amplifier
Jon Z
11-19-2006 10:23:56
Was into the tranny so I thought I would look at the torque as long as I had it all apart. It was working good and the only wear I see is that some of the sprage rollers are egg shaped. Can a guy/should a guy replace just them?
John
jbia
11-24-2006 08:59:47
 Re: 400 Torque Amplifier in reply to Jon Z, 11-19-2006 10:23:56
if you replace the rollers and springs make sure you replace the copper pins also or you might be spliting her again shortly
randy hall
11-19-2006 11:47:03
yes you can buy just the springs and rollers and yes you should replace them.
