new head studs for super m
jim kurgan
11-19-2006 13:44:54
I am looking to replace the studs on my tractor during my engine rebuild.the studs are all either too short or the threads are chewed up. Where can i find them. Also do i put sealer on the mating surface or not? The kit doesn't say. thanks
El Toro
11-19-2006 18:09:33
 Re: new head studs for super m in reply to jim kurgan, 11-19-2006 13:44:54
I would check those threads in the block for any wear. You may need helicoils installed if the threads are worn or the stud holes are worn. Hal
r4etired
11-19-2006 17:40:43
CIH has them,just bought some 3 weeks ago.
Janicholson
11-19-2006 15:46:21
The studs can be found at a good fastner company take the old ones with you they have different threads on either end. They need to be quality grade 8 or better to assure correct torque and sealing of the head. I use coppercoat spray on both sides of the gasket, then let it dry hanging on a nail for an hour. Good luck, JimN
