Order Farmall Cub Parts Online
polarizing generator 51 cub
J W Bishop
11-21-2006 06:47:01
I am converting back from neg - ground to pos + ground. Need some help. Would someone please post a drawing or diagram on how to polarize generator 51 farmall cub. 6 volts thanks
John T
11-21-2006 07:15:46
 Re: polarizing generator 51 cub in reply to J W Bishop, 11-21-2006 06:47:01
Use a jumper wire etc to momentarily flash jump from the VR's (or cutout relays) BAT terminal over to its ARM/GEN terminal n you ought to get s spark. The same things accomplished by flashing any hot ungrounded battery voltage source (like is present on the VR or cutout relays BAT terminal) direct to the gennys ARM post n get the spark. BE SURE n do that before you fire her up!!!!! !!!!! !
If its a coil ignition swap coil leads so the + terminal wires to the distributor (- gets voltage from ignition switch) and if it has an ammeter n youre changing polarity its leads need swapped or else it will read bass ackwards
John t
K-Mo
11-21-2006 07:05:00
With engine off, touch a jumper from BAT to the GEN terminals on the regulator for a couple of seconds.
K-Mo
