Help ID this tractor
Dirtdog
11-21-2006 14:49:50
third party image
Anyone out there recognize the model of this IH industrial tractor?
It has a gas engine (engine has a C200 number on it), shuttle trans, front loader and rear trencher. Trying to ID so we know what model to order parts for.
Thanks for any help.
Weldon K
11-23-2006 07:03:51
 Re: Help ID this tractor in reply to Dirtdog, 11-21-2006 14:49:50
I case you need to know the model of the loader also, it is the industrial International 3000.
BillyinStoughton
11-22-2006 08:18:17
2544 all the way. Got plenty of seat time in one of those! The C200 gives it away too. That's a non-sleeved block...the same thing I have in my Farmall 544. That engine is only used in some of the hundred series ending in 4.
Billy
FarmallBob
11-21-2006 18:46:34
Dirtdog,
Where you from? Do you know that juy sitting on the tractor? Looks exactly like someone I know.
Bob
Dirtdog
11-22-2006 07:20:31
 Re: Help ID this tractor in reply to FarmallBob, 11-21-2006 18:46:34
Texas, and yes I know him.
K.B.-826
11-21-2006 17:09:10
Definetly a 544 Utility or a 2544. That grille is unique to the 544/656, the 656 of course would have had the six-cylinder enigne. I"m not exactly sure how to tell the difference between a 544 Utility and a 2544, but pretty much all of the engine and drivetrain parts should be the same. Check for a model/serial number tag, should be located on the bell housing.
Dirtdog
11-22-2006 07:19:27
 Re: Help ID this tractor in reply to K.B.-826, 11-21-2006 17:09:10
Thanks for the replies. The SN tag on the bellhousing missing. Just a couple rivet heads all thats left.
Thanks
KIP in MX
11-21-2006 16:29:30
Looks like a 4 cyl engine. Iīll guess itīs a 2544 industrial.
Dirtdog
11-22-2006 07:35:40
 Re: Help ID this tractor in reply to KIP in MX, 11-21-2006 16:29:30
Sorry, it is a 4 cylinder gas engine.
Allan In NE
11-21-2006 16:50:32
Yep,
Think you're right. Danged 4-pop thru me! :>)
Allan
Allan In NE
11-21-2006 15:52:02
International 656 Hydro.
Allan
