Farmall 504 need part
Adam Brock
11-21-2006 20:12:23
I have a Farmall 504 that I need the block off plate that goes where the control valves bolt to the side of the housing. Anybody have one??
trulyred
11-21-2006 20:54:33
 Re: Farmall 504 need part in reply to Adam Brock, 11-21-2006 20:12:23
Be careful about blocking off completely, on an open circuit such as this you must have oil flow or you may damage the pump.
jeff311
11-23-2006 11:18:22
 Re: Farmall 504 need part in reply to trulyred, 11-21-2006 20:54:33
trulyred is correct. Don't block off the flow with the wrong plate. The IH part you need is 376 023-R3. That is the correct backing plate that will allow oil to flow around the valve mounting surface and complete the circuit without the valves attached.
I have 2-3 of these contact me if you are interested. jeffsbigdawg@aol.com
JayWalt
11-21-2006 20:37:16
If it is like my 300u valves, if I needed a cover plate, I would make one out of plate steel. Best bet is to go to the nearest steel supplier and look through their "shorts" dumpsters. I could get a piece of 3/8" plate about that size for less then $5, then drill the 4 mounting holes. If you wanted to get real crzy u could take it to a machine shop and have the contact surface resurfaced, but I bet it would be fine, as its pretty hard to really bend something that small and thick.
If I had one to give ya, I would!!
