Hydraulic Control Valve
Triker
11-22-2006 06:55:56
I get confused on the hydraulic set up on my H. I have added a loader and also have a 3pt hitch on the back. Will installing a control valve fix the problem of not having to get off the tractor to switch hoses back and forth? If this is the answer, does anyone have any pictures of how to install one and/or have one for sell? Thanks.
Wardner
11-22-2006 07:48:41
 Re: Hydraulic Control Valve in reply to Triker, 11-22-2006 06:55:56
I think that people who have simple hydraullic plumbing questions need to start looking at catalogs. Some of the better ones even have sample layouts and explanations of how hardware works. Most everything I know about hydaulics came from these very same catalogs. Roberts Electric in Chicago has a good one. I don't think they have a website but if you get on their mailing list, you will be getting catalogs for the rest of your life. For me, that is a good thing. It is a great how-to reference. Their name is a little misleading. They are mostly into new and used hydraulic hardware.
Anyway your simplest solution is to get a two spool valve. I never buy them. I always opt for three spool valves because I like having the option of expanding my hydraulic applicatiions. For alot less money, get a selector valve. It will give you two circuits but not at the same time.
Jaywalt
11-22-2006 07:38:59
That depends. How many sets of cylinders (plumbed in parallel if for lift arms, dumps etc) does the tractor have. you need one valve for each set of cylinders That work together. I have one hitch cylinder, 2 lift cylinders and 2 dump cylinders. I only have 2 valves, so I am using 2 "valve selectors" to select between the dump cylinders and the rear hitch. It all depends on your setup, pics would be helpful as well.
