Farmall C trouble
IHC-Farmall
11-22-2006 09:43:01
I got a farmall c and when i start it, it smokes and my oil is way over full, then i try the hyds. and nothing, the hyd oil got into the engine oil. I was wounding how this could happen? Is there a check valve from where the oil goes into the pump?
IHC-Farmall
11-23-2006 08:30:36
 Re: Farmall C trouble in reply to IHC-Farmall, 11-22-2006 09:43:01
I put a seel in and put it back together, now it is running great. THANKS FOR ALL THE HELP!!
Cedric
11-23-2006 00:38:51
I can email the Instruction Manual for the disassembly, inspection, seal installation and reassembly of the pump if you would like. It is a handy piece of literature to have. Sid.
banjo
11-22-2006 21:53:01
when you get the pump off look on the side that was against the block and write that number down. If you decide to overhaul the pump it will have a suffix number,01,02,03,04,05. the last two numbers is the suffix. depending on which one it is dictates which seals to use.
If i was going to replace one 0-ring i would replace them all while i had it off.
El Toro
11-22-2006 16:25:18
Chicago-Rawhide may have a seal too. You can call them at 1-800-882-0008 to find your nearest store. Hal
IHC-Farmall
11-22-2006 15:57:29
Ok i got the pump taken apart, the smooth shaft has no grooves, the other day when i got done using it the oil was a little over full nothing bad, but this morning when i went out there was no hyd and all the hyd fluid went into the engine, the tractor has been sitting all summer, could have a seel been craked from sitting then when i started using it break right out? I think the seal is completly gone, is there sopposed to be seels inside of the cover or body berings? When i have that smooth shaft out i can move it back and forth, but not side to side, is there sopposed to be a seel on the top or bottom sides of thoses?, when i look down the part of the pump that the shaft came out of all i can see is one seel and there looks like there is a spot for another behind it, is there sopposed to be one there?
Thanks for all your help!
El Toro
11-22-2006 16:20:02
 Re: Farmall C trouble in reply to IHC-Farmall, 11-22-2006 15:57:29
Take a look at No4 seal in the parts breakdown that I sent you. Hal
El Toro
11-22-2006 13:53:05
third party image
Here's what your pump parts should look. Hal
Bill Geer
11-22-2006 10:03:37
It is the seal on the hyd. pump.
Be sure the shaft is smooth when replacing the seal.If there is a groove I think you can get a speedy sleeve for it.
IHC-Farmall
11-22-2006 10:22:03
 Re: Farmall C trouble in reply to Bill Geer, 11-22-2006 10:03:37
Where would i find the seal? Would i have to take the 4 bolts off?
gene bender
11-22-2006 16:59:04
 Re: Farmall C trouble in reply to IHC-Farmall, 11-22-2006 10:22:03
there is two types of seals used one takes an o-ring the other takes a small seal and you wont know which until it is apart. If the shaft has a groove where the seak runs you will need a speedy sleeve to repair the grove.
scotty
11-22-2006 11:07:05
You need to drain the touch control,pull the hydraulic lines off, remove the pump and seperate the assembly. The seal is an o-ring that rides on the driven pump shaft, The o-ring is available from Case IH. I also have another supplier if they dont want to be bothered.
Gordon Rubber & Packing Co Inc. Derby, Ct 203-734-7152
Good Luck!
scotty
