I came close to buying a gasser with the thought in mind to make some improvements. Diesel fuel is still more expensive than gas, so the running economy advantage for a diesel is somewhat negated by that. I considered converting a gas tractor to propane because propane is even cheaper than gas or diesel, though they tend to burn more gallons. I also considerfed converting it to a fuel injection system (a throttle body EFI system) to increase efficiency by 5-10 perrcent by most estimations. In theory, you could convert a gas tractor to run on E85 fuel, which is 85 percent ethanol (burn what you grow!). For the small farmer that runs few hours per year, a gasser makes more sense. On average a gas engine will use 30 percent more fuel than a diesel. Let's say you use the tractor 50 hours per year. A diesel using 4 GPH for 50 hour would use 200 gallons. The average price around here is $2.55/gallon, so that's $510. An equivalent power gas tractor would use about 5.5 GPH, so that's 275 gallons. Right now the average proice for gas is $2.20 a gallon so that's $605. a year, an increase of $95. Lets say the average price of the diesel tractor you want is $6500 for a decent but high hours unit. Looking around you can find find similar HP gassers for about $4500, usually in better shape and with lower hours, a difference of $2000. How many years at a savings of $95 a year will it take to pay off the higher cost of the diesel by fuel economy alone? My calculator says 21 years for the 50 hour a year farmer. FWIW, these are the numbers I played with when I made up my mind that I would accept a gasser.I had been looking at diesel tractors and in the HP I wanted, they were in the $6-7000 range for a decent unit locally. In the search, I found a pristine 90hp (green) 4020 gasser with 2500 hours for $4500 (at a dealer no less) and if one of their sales guys hadn't been a total bozo, I'd be runnning it now. A week later, I was driving my very tired 826. It was pretty cheap and it's very economical even by diesel standards, but I've also had to put a fair bit of money and time into it. Objectively, that 2500 hour unit was the better tractor mechanically and it probably wouldn't have had as many (or any) problems. 'Course I wouldn't have met all you wunnerful red tractors guys either!! And how can you put a price on that!
