International casting numbers Identification. HE
Sam F.
11-23-2006 12:39:07
Can anybody tell me what the following casting numbers are on ?? I bought what "think" is an International 140, but someone has taken the serial tag off the clutch bell housing.
362771R1--Axle Housing
361687R8 or 361887R8 Torques Tube
367657R5 Hydraulic Pump housing
108772 Motor serial number
G 123 on the motor
Tractor does not have grill so hard to identify. Please help.
Stan(VA).
11-27-2006 05:04:58
 Re: International casting numbers Identification. in reply to Sam F., 11-23-2006 12:39:07
Sam,
I would start by looking at the fan belt(s) on the engine. If you have 2 belts, one wide and one narrow, the tractor would be a 100 or 130; if you have one narrow belt that drives everything it is a 140. The engines casting number is just behind the oil filter. A 100 would have a 354898R, a 130 would have 366204R, and the 140 would have 367825R. Assuming original block has not been replaced.
Stan(VA).
