engine for a model B
matt fleisher
11-23-2006 19:27:43
My father-inlaw has a B that has a cracked block on the manifold side.First,does anyone have an engine for it? Second, does a 140 block,use the same crank and cam as the B. I need advice.I live in southwest lower michigan. THANKS FOR THE HELP IN ADVANCE. MATT
Pirate Fan
11-24-2006 16:09:55
 Re: engine for a model B in reply to matt fleisher, 11-23-2006 19:27:43
I have an engine in a 1946 A which runs very good but needs carb. I bought tractor for sheet metal. Will sell wtih everything including pressure plate, clutch, manifold, oil filter, actually complete engine. Just needs to be pulled out of tractor which I will do. Please advise.
Red Dave
11-24-2006 04:43:11
If that crack is behind the carburator, it may be able to be repaired without too much trouble. It is in a water passage that breaks when it freezes without antifreeze in the block.
Lots of A,B,C blocks have this crack.
Bill Geer
11-23-2006 21:49:08
Matt Try this guy Robert Swartzlander.
269 468 5047 He is in Coloma MI
tn terry t
11-23-2006 20:12:46
you might look into having the block repaired behind the manifold cracks pretty comon on those engines
