e-85 706 ?
Jon Heili
11-24-2006 07:35:07
I have wondered for a while if I could run e-85 in my 263 706 instead of 93 octane arab oil. It is supposed to have 103 octane, but also is more corrosive. We run it in our 03 ford taurus, and my 05 seirra. I am just wondering if anyone has run it, and had or did not have any problems. Thanks
MN Scott
11-24-2006 10:37:04
 Re: e-85 706 ? in reply to Jon Heili, 11-24-2006 07:35:07
You still will be burning that Arab oil as it takes nearly 1.5 gallons of it to make each gallon of ethanol from corn.
Aces
11-24-2006 10:16:33
The only difference between an e10 engine and an e85 engine is the e85 fuel lines and injectors are 1/3 bigger. and stainless steel.
ChadS
11-24-2006 10:02:41
 It will run on it,,,,,,,,,,,,,,,BUT,,,, in reply to Jon Heili, 11-24-2006 07:35:07
Yes, it can run on it. But you use alot more of it,,, Not a real cost saving option, since they wanna jack the price up too,,, but yeah,, it will run on it. You wont be completly away from oil,, but will drop the amount of it you use in your machine. Gotta mix it in with gas so it will run smoother,, running it straight,,,, HAHAHA!! That ol 706 would sound like a top fuel draggster at idle!!! I know!! Thats what my 460 puller drinks up everytime it pulls!! Darn thing gets thirsty!! I think it has a drinking problem,,,, But yeah,, they run on it. Not hard to do,,, consider it more of a conversion,, like going from gas to LP,,, Few things to consider on doing this,,, run a compression test, that reading will determine how much ethanol you can mix in with gas so it will run smoothly and not drop power. Other than that, its all done to the bowl of the carburator. Drill the jet, and the bottom two holes of the metering stem till you can back the adjuster screw out and make it run rich, from too much fuel. Need to retard the timing more on ethanol,,, its a cold fuel, and needs time to get the fires lit, not like race fuel, or pump gas that fires quickly,,, Once the jet is big enough, you can probably put back in the electronic shut off,,, but make sure its adjusted so it dont lean it out when its in run,,,, Best fire up the still,,,, that 706 will get thirsty on this stuff!!!!! Oh, yeah, the octane value is higher than 10 dollar a gallon racing fuel, but,, dont tell them that,,,, Hope ths helps,,, Need to know how much compression, that can tell how much to mix in with your pump gas. But yeah,,, it will run on it.
Brian in MO
11-24-2006 07:49:17
I thought the e-85 could only be ran in vehichles specially designed to run that fuel at least from everything I have read. How are you running it in this other stuff and how long have you been using it? I suspect it will cause problems in the long run but maybe not. I'm all for useing ethanol blended fuel and I burn that in everything.Brian
Jon Heili
11-25-2006 05:27:01
 Re: e-85 706 ? in reply to Brian in MO, 11-24-2006 07:49:17
I thank you for the help, sound like a losing deal. My car is a flex fuel, And in my truck I run 50% e-85, 50% 87 octane with no problem other than a slight drop in mileage. I have been told e-85 has a higher oxygen count than gas, and will trip your o2 sensor, and your computer will retard timing and engine runs poor. So as long as check engine light doesnt come on I dont think there is any damage being done.
