Problem correcting posts
Don L C
11-24-2006 15:41:49
When I post any where on YT .....and hit the back button to make corrections.....I lose the whole thing.....Don
Randy as in Randy-IA
11-25-2006 10:22:08
 Re: Problem correcting posts in reply to Don L C, 11-24-2006 15:41:49
Another thought is just write it in whatever email you use then you can use spell check ;) then copy it to notepad and paste it into the forum comment box . I've done that when there's some simple one letter words I've forgotten how to spell . Happens all the time these day's ! Take care ! ...Randy
RustyFarmall
11-25-2006 07:13:01
I have found it is easier to proof read and correct your message before you hit "preview your reply".
Allan In NE
11-25-2006 07:20:53
 Re: Problem correcting posts in reply to RustyFarmall, 11-25-2006 07:13:01
Darnit Rusty!
Quit trying to confuse me with logic! What fun is that? :>)
Allan
Honest Jon
11-25-2006 06:51:33
Happens to me every time I hit the back button. Extremely exasperating. These forums are one of the few that I know of that do not have an edit function once a post has been made. It borders on the primeval.
williamf
11-25-2006 01:52:12
Mine goes through spells of that, too. Irksome.
Sometimes it's weeks of it. Usually gets better about the time I start remembering to "Copy" the text before I hit "Back."
Good Luck, Wm
JayWalt
11-24-2006 21:51:29
Yes, that happens to me sometimes, but not often. I love this forum and the people here are awesome, but the forum software leaves alot to be desired...
Oldman1151
11-24-2006 16:00:08
I have the same problem. It seems no matter how many times I check my wording I find errors in the preview or even after posting. What I have learned to do is copy the post to the clipboard before going to preveiw. Do this by highlighting all of your text and hit control C(hold down control button and c at the sametime). If you find an error or want to change something after seeing the preview hit the go back button and just put your cursor where you want the text and hit control v(hold down control button and v at the sametime). This should put everything back as you typed it the first time. Make you your changes and repeat as necessary. You will still have to enter your name, subject and email each time.
