Order Farmall Cub Parts Online
Cub cadet lawn tractor
Randy as in Ran
11-26-2006 17:16:34
Hi All , I have a 1811 Cub Cadet Hydro that I use a snow blower on and I always get stuck even with chains . My 265lbs doesn't seem to be enough counterweight for the weight of the blower hanging out front . I was wondering if anyone knew what size wheel weights might fit ? In other words which tractor wheel weight will fit a lawn tractor rear wheel ? The tire size is 23x10.50x12 . Thanks ...Randy
Red Dave
11-27-2006 04:38:14
 Re: Cub cadet lawn tractor in reply to Randy as in Randy-IA, 11-26-2006 17:16:34
Early Cub Cadets used the same wheel weights on the rear as the front weights on a Farmall Cub. They are still available, but usually run $100-$150 a pair around here. Besides, they only add about 15 pounds on each side. And I don't know if they'll fit your model.
I made a bracket for the rear of my 125 that I set a piece of railroad rail on for weight.
11-27-2006 17:50:35
 Re: Cub cadet lawn tractor in reply to Red Dave, 11-27-2006 04:38:14
Thanks Dave . That's what thought so I guess I can cut a couple rounds of 1/2" plate to fit inside the rim . I think about 150lbs more should work so I'll find a place to put it somehow . ...Randy
