Order Farmall Cub Parts Online
Re: Cub won't start after rebuild
Kermit
11-26-2006 18:46:11
Yes, checked all four - all have good spark.
El Toro
11-26-2006 18:59:21
 Re: Cub won't start after rebuild in reply to Kermit, 11-26-2006 18:46:11
That's sure weird. Have you measured the compression. When you had No1 piston on the compression stroke, did you look at the valves on
on that cylinder? Hal
Kermit
11-26-2006 19:14:17
 Re: Cub won't start after rebuild in reply to El Toro, 11-26-2006 18:59:21
No, I haven't checked the compression. Do you mean did I check to see if both valves are closed during compression? I did have the valve adjustment plate off when I was installing (timing) the magneto and it looked like both valves were closed as #1 hit the TDC mark on the pully.
El Toro
11-26-2006 19:22:18
 Re: Cub won't start after rebuild in reply to Kermit, 11-26-2006 19:14:17
That's where they should be. I guess we will have to sleep on it tonight. Hal
