Super-A hydraulics
48--A
11-27-2006 07:53:57
The hydraulic cylinder and valve unit on my '48 Super A has one stuck cylinder (right side) and it leaks. I am removing it to repair. I am looking for the head and cover gaskets.
Mark in WA
11-27-2006 11:06:11
 Re: Super-A hydraulics in reply to 48--A, 11-27-2006 07:53:57
I purchased this rebuild kit and installed on my 49 last winter. The kit is basically all the O-rings and seals needed to overhaul the hydraulic manifold. Just bee sure not to gouge any of the pistons, valves or walls when removing old parts. You may need to use air pressure to remove some of the valves. Just be carefull not to use too much, probably no more than 20 psi would do. This is not my preferred method but I found no other way to remove them. There aren't very good instructions as to which O-rings go where, but it isn't too hard to figure out.
48--A
11-27-2006 10:06:28
Thanks for your help!! Is kit # 354007R96 the complete rebuild kit that costs $110? I can"t tell from the CaseIH description. The complete kit is what I want.
scotty
11-27-2006 09:27:56
Just to add to what K-Mo said, the whole rebuild kit for the touch control and pump is bout $110.
scotty
K-Mo
11-27-2006 08:12:31
CaseIH or Google Kit No. 354007R96
You can look up the parts you need at www.caseih.com and follow "Search for Parts"
K-Mo
