350 hydraulic filter screen
Tracy Bowen
11-27-2006 13:54:06
Dose anyone know where the hydraulic filter screen is located on this tractor. Is it under the seat or under the dash panel. Please let me know I need to clean the screen.
Dave McCallister
12-01-2006 18:14:52
 Re: 350 hydraulic filter screen in reply to Tracy Bowen , 11-27-2006 13:54:06
If it is a 350 utility it is under the seat beneath the heavy akward cover as stated above.
If you need to change the filter, you need to clean out that tank as well.
Dave
Satsop
11-27-2006 18:31:59
Tracy
If it's a utility it is in the tank under the seat. Get some help or use rigging as the tank cover is very heavy and awkward.
Jim
Hugh MacKay
11-27-2006 14:23:22
Tracy: Farmall or Utility? Farmall has it just ahead of clutch pedal on left side of hydraulic unit. I expect Utility has it under seat, not sure where though.
cbl
11-27-2006 15:15:25
 Re: 350 hydraulic filter screen in reply to Hugh MacKay, 11-27-2006 14:23:22
Are you sure Hugh? Thought on the Farmall it was on the right side in front of the brake.
Hugh MacKay
11-27-2006 16:03:12
 Re: 350 hydraulic filter screen in reply to cbl, 11-27-2006 15:15:25
cbl: By gosh now that you mention it, I'm not sure. should know, I once had a 300. I guess I've been playing around with these little offsets too long.
Regardless, I guess we could tell him it's a square cover or cap with rounded edges, 4 small bolts hold it in place and it has a recessed circle in middle about 1.5" in diamater. Those small bolts are probably 2.5" apart in a square pattern. That is the Farmall. That bolt pattern will be common to the Utility. Not just sure the square cap is exactly the same. Am I doing any better.
