H trans gears and engine questions.
H fanatic
11-27-2006 19:25:49
Hello,
I have a few questions to ask. One is what are the transmission gears made out of in a 1946 Farmall H, Cast Steel or Cast Iron? They appear to be cast, but cast what? And second, in a 1946 Farmall H engine, Can I put stepped head pistons without doing any block or head modifications. And if I can put them in without any block or head modifications, where would be the best place to get a set of pistons and sleeves? New or used?
Thanks Nick
riverbend
11-28-2006 15:56:40
 Re: H trans gears and engine questions. in reply to H fanatic, 11-27-2006 19:25:49
I have looked through my manuals and parts book, and I cannot find any mention of what the gears are made out of. So, I'm no help there, but I am curious, what are you doing where the gear material makes a difference ?
You can put stepped head pistons in and use any head. The dome on the IH "firecrater" pistons is only 21 ccs. The cylinder volume, not counting the head, is roughly 650 ccs. If you are just putting in stepped head pistons, you could be looking at something under a 3% increase in compression ratio.
If you are going to all that trouble, why not use new parts ? This site has reasonably priced piston and sleeve kits, that I hear are decent quality.
Greg
H fanatic
11-29-2006 18:31:12
 Re: H trans gears and engine questions. in reply to riverbend, 11-28-2006 15:56:40
Greg,
I need to know what the gears were made out of because I need to repair one. I found out they were made out of cast steel. Thanks for all the uesful infomation you gave me.
Nick
