Farmall H Loader, Hydraulics Problem
Matt Compton
11-28-2006 14:52:33
Hey Folks Since the snow is getting closer by the day, I decided to drag out my old #30 McCormick Loader, and hook it to the "H" for the first time. The tractor has the belly pump. When it came to hooking up the hydraulics I thought I would use a control valve from another loader, vs the control valve on the "H" Now the problem is that the loader goes up, but doesn't go down VERY well, and will actually stop going down. When I move the lever from the "h" to down position and the control valve on the loader to down, the loader goes down no problem. Have I confused you yet?
I Figured even with "h" control valve always in the up position the loader should go down when the external control valve is moved down. As the return line from the external control valve is plumbed back to tank.
Could the control valve be faulty?
any suggestions on how to do this properly would be greatly appreciated.
Note, I did remove the Vent cap, and it made it no better
thanks alot, hope i didnt confuse you to much
Matt
Delbert
11-28-2006 17:59:45
 Re: Farmall H Loader, Hydraulics Problem in reply to Matt Compton, 11-28-2006 14:52:33
I have used a no. 30 loader on a h with a control valve. What you need to do is preasure in from pump then out to bottom of belly pump. Lock and tie back the control rod so pump runs all the time. You then can use a single hose from valve and tee to both cylinders it will work. Like back to raise and forward to lower you will lose some lifting power this way but will work. You will still need your return lines in the top of the pump from the front of your loader cylinders. I have you totaly confused i know. But i did it this way. And ran a 3 pt hitch with two double action cylinders and also a mower with double action. I have a triple action valve on mine. This is a belley pump.
Matt Compton
11-29-2006 01:50:47
 Re: Farmall H Loader, Hydraulics Problem (ATT Delb in reply to Delbert, 11-28-2006 17:59:45
I've got mine plumbed the same as yours delbert, i'm starting to wonder if my spool valve is the problem? Because the loader will actually go up very slow in the down position some times. maybe i'll try a new valve
Nat 2
11-29-2006 05:05:02
 Re: Farmall H Loader, Hydraulics Problem (ATT Delb in reply to Matt Compton, 11-29-2006 01:50:47
Either you have the spool valve plumbed incorrectly (i.e. it's not as you think it is), or the spool valve is not working properly.
Unless you have dual-acting cylinders for the lift, there's really no point in having a second spool valve. Just use the ports sticking out the side of the tractor's torque tube, the single on the one side and the front port on the other. Plumbing is much simpler that way, too.
T.B.W.
11-28-2006 17:37:05
I ran a line from the outlet on the belly pump to the" in "side of the spool valve. I ran a line from the return of the spool valve to the drain plug hole of the belly pump. When I wanted to use the loader, I locked the belly pump control rod pull out all the way and ran the loader up and down with the spool valve. I also conected the lines to the cylenders of the loader to the pressure side of the spool valve. worked great for me. the only problem is the clutch has to be out for it to work.
Allan In NE
11-28-2006 15:15:34
Yep,
That's not gonna work. Either use the H's system or get a separate PTO pump/tank and use your other valve.
You're trying to keep dogs and cats in the same room here. They are fightin' each other. :>)
Allan
RustyFarmall
11-28-2006 15:08:16
Get rid of that extra control valve and plumb the hoses from the top of the cylinders back into the fill pipe for the belly pump. The only control valve you need is the one that is in the belly pump.
JayWalt
11-28-2006 15:05:28
How did you plumb the control vavle into the existing system Why not just use the stock control valve, it should work fine...
Matt Compton
11-28-2006 16:07:26
 Re: Farmall H Loader, Hydraulics Problem in reply to JayWalt, 11-28-2006 15:05:28
I got it plumbed as follows
pressure line from belly pump to inlet of control valve
return line from control valve to fill port of belly pump
pressure port of control valve to cylinders
the reason i got it hooked into this is becuause I am gonna use the control valve so i can hook it up to 2 way hydraulic implaments that I own, IE a mower
Allan In NE
11-28-2006 17:09:06
 Re: Farmall H Loader, Hydraulics Problem in reply to Matt Compton, 11-28-2006 16:07:26
Matt,
See where the bind is?
The H is a one-way system and you're trying to run it thru a two-way valve.
Just isn't gonna work, ol' Sport. You either need a one way (read: dump) valve or a loader that has two-way cylinders.
The way you have it plumbed now, when you want to "lower", that oil has no where to exit to because it is dead-heading (except for the bleed channel) inside that valve.
Allan
Nat 2
11-29-2006 05:13:38
 Re: Farmall H Loader, Hydraulics Problem in reply to Allan In NE, 11-28-2006 17:09:06
Allan,
There's nothing wrong with trying to run the H's one-way hydraulics through a two-way valve. Two-way valves (i.e. the christmas tree valves) have been an option on the letter series Farmalls from almost the beginning. In fact, that's how hydraulics work on any tractor... One-way fluid is redirected through a two-way valve to make two-way hydraulics.
The REAL problem is in trying to operate a one-way cylinder through a two-way valve, for the reasons you stated. In this case, the pressure is probably bleeding by a worn spool, causing the loader to go up sometimes.
I just wanted to make a correction because what you said is kind of misleading, and would cause some people to think that you can't have two-way hydraulics on a letter series tractor.
Allan In NE
11-29-2006 05:39:35
 Re: Farmall H Loader, Hydraulics Problem in reply to Nat 2, 11-29-2006 05:13:38
Hi Nat,
No, didn't mean that at all.
What I was trying to say was that if he is using a "one-direction" system, he has to use a "one-direction" valve.
Sounds like he is trying to make an old one-way loader work with a "two-direction" valve. :>)
Allan
Harold Hubbard
11-29-2006 04:39:31
When I added the two way spool to my M, I still needed to be able to hook up single acting cylinders from time to time. So, instead of plumbing the new valve in permanently, I put a quick disconnect in the pressure line. That way I can unhook the two way valve, and feed a single acting cylinder directly, using the control on the belly pump.
