belly implements for super c
novice guy
11-28-2006 15:02:04
they tell me my super c was designed for belly implements like plows cultivators mowers etc. does anyone know where you can get them or all they extinct?
Craig W Amundson
12-09-2006 05:38:57
 Re: belly implements for super c in reply to novice guy, 11-28-2006 15:02:04
Super C implements can be hard to find. Mine came with a 1 bottom plow, which hooks up on the back and a rod goes forward to hood up to the side pto to lift the plow when needed. It also came with a 7 ft sickle mower, loader, snow plow attachment for the loader and some kind of attachment for the loader that I think was used to pick up hay bales in the field. It also came with chains. I have seen grader blades on them but no other belly implements, though they may have made some from the factory. I would be interested in buying a belly balde if someone knows where one is
JohnG(TX)
11-29-2006 10:59:30
I stole a 1952 Super C for $150 earlier, and it came with all the implements. I got a full set of cultivators, rear mounted middlebuster, two-row mounted planter, and rear sickle bar mower. I have seen (and will get soon enough) a front mounted two-row middlebuster and rear disk plow. Check eBay, occasionally there will be a parts catalog for C and Super C Implements. Basically all the stuff that will bolt to the tractor. It comes in Fast Hitch, and Mounted. I have the Mounted version since I have no Fast Hitch.
wegman in Mn
11-29-2006 04:32:50
paul shuler, my grandpa used to haul milk cans with one of those on a super c
TDK
11-28-2006 20:49:13
How about a two - way moldboard plow or 7' sickle mower. Send me an email for details.
novice guy
11-30-2006 03:37:16
 Re: belly implements for super c in reply to TDK, 11-28-2006 20:49:13
i would be interested in seeing some pictures of them and what you want for them
TDK
11-30-2006 17:56:28
 Novice Guy !!!!!!!!!! in reply to novice guy, 11-30-2006 03:37:16
I sent you an email.
Paul Shuler
11-28-2006 19:37:58
Here a few photos of some of the stuff I have for my super C. One thing I don't have a photo of yet is the post hole digger I bought from FarmallHal that you may see lurking around on this site no and then. The blade you see on the front of my tractor will also mount under the belly.
Paul
farmallhal
11-30-2006 18:31:54
 Re: belly implements for super c in reply to Paul Shuler, 11-28-2006 19:37:58
Paul, are you using that snow blade yet? Snow is coming down up this way after several inches of sleet fell during the day. Sleet made everything white but ground is still warm and it melted next to the ground so everything is a slushy mess now and will be frozen solid by in the morning is my guess. Take care and you might want to mount that blade for driveway duty. Hal
mostly green
11-28-2006 15:59:02
I've got a Horn hydraulic front end loader that fits a Super C. If interested e-mail me back.
novice guy
11-28-2006 18:13:07
 Re: belly implements for super c in reply to mostly green, 11-28-2006 15:59:02
already have a mckormick front loader on my "C" i am looking for the plow more then anything but thanks
