M new seals, how much grease
Paul G. in Mn
11-28-2006 15:48:16
I just replaced the rear axle seals and wondering how much grease I should give them thanks Paul
NO tools
11-28-2006 17:05:34
 Re: M new seals, how much grease in reply to Paul G. in Mn, 11-28-2006 15:48:16
Paul
Use the grease as you desire?
It is just a safey type of procedure.For OFF level ground.
THEM outer bearing actually oil from rear end OR trans oil.
WE use to pump 20 pumps in new bearing after installing?
Kind of go from there on desired use of tractor.
Bill
