Order Farmall Cub Parts Online
Replacing brake bands on cub
J W Bishop Sr
11-28-2006 15:52:44
What steps do I take to replace brake bands on my 51 cub tractor on the right side. Thanks
Keith-OR
11-28-2006 23:20:18
 Re: Replacing brake bands on cub in reply to J W Bishop Sr, 11-28-2006 15:52:44
J W, you will need to jack up and support rear of tract. 1 remove wheel, 2 remove fender, 3 remove drawbar or fast hitch from the rear housing. 4 Remove bolts holding the rear axle housing from the transmission. 5 Support final drive assembly, and remove it from tractor. 6 Then you can remove the brake band from the housing.
Loosen the locknut and set screw on the brake drum. Then remove from the differential shaft.
Here is a link to the parts break down of the Cub differential. Page 42...HTH Item 10 is brake drum
Keith & Shawn
