784 international diesel $$$$$$$$$$$$$$
lekander883
11-28-2006 17:50:39
Would anyone be able to tell me how much an international 784 4 cyl. diesel with a front end loader in nice condition worth.
Mich John
11-30-2006 04:06:13
 Re: 784 international diesel $$$$$$$$$$$$$$ in reply to lekander883, 11-28-2006 17:50:39
Hi jb2,
Was wondering if anyone else out there had a 784 or similar model. I had to go thru the front end also when I got mine as it was wandering all over the place due to tie rod ends, bushings & pivot "slop". Haven't freed up the diff. lock yet either - will keep on with the PB Blaster and some light taps.
John Litzelman
11-28-2006 17:56:28
I paid $7300 for mine 2 years ago at a farm sale with a 2250 mount-o-matic 84" bucket loader here in south central Michigan. The tractor had low hours but had sat outside and the paint was faded, fenders had rust but it appeared in good mechanical condition. Had to replace a rear whl rim (one with 8 welded on rectangular pads to attach the cast center hub; a rare wheel which I had a hard time finding) but rest of stuff was just lack of TLC & neglect over the years.
lekander883
11-28-2006 18:04:25
 Re: 784 international diesel $$$$$$$$$$$$$$ in reply to John Litzelman, 11-28-2006 17:56:28
would 3442 be a lot or low hours for this tractor?
Fromjb2
11-28-2006 21:05:01
 Re: 784 international diesel $$$$$$$$$$$$$$ in reply to lekander883, 11-28-2006 18:04:25
Hi John, my brother just paid $9000 CND for a 3230 with 1400 Hrs and no loader. Transferred 2250 loader from his older 495. The 3230 is two generations newer same as 584. Models were 484,584,684,784 and 884.
Re 3442 Hrs., engine should be good for 15000 Hrs or more. Check the front end for being loose. A 2250 loader can cause front end problems. Keep the bolts and the fittings greased. The 84 series has a better front axle than the newer 95 series.
JB2
