repower of H farmall
timmy prochaska
11-29-2006 09:46:23
What's the cheapest easiest route to repower the H farmall? Thanks,Tpro
Steven@AZ
11-29-2006 11:49:57
 Re: repower of H farmall in reply to timmy prochaska, 11-29-2006 09:46:23
Cheapest and easiest repower for a Farmall H?
If you are looking to increase horsepower, buy a running 300 or 350 and swap the engine into it.
If you want to increase efficiency, there is no cheap or easy way to do that.
arod
11-29-2006 11:08:43
cheapest? ha ha, well, compression.
1) re-ring $160, re-sleeve if necessary $ ???
2) have the cylinder head rebuilt, $300
3) tune up the governer
I would focus on compression. rings, head(valves) governer
gene bender
11-29-2006 10:06:28
Now that depends what kind of power you want and of course the use when done. Anything from new sleeves pistons to a large cu in car or deisel engine.
