340 industrial power steering problem
suumoe
11-29-2006 19:03:16
I recently purchased a 340 Industrial with a Lord front end loader. When I first start the tractor the power steering is fine for a couple of seconds, then it starts to tighten up and I get a small whining noise from the trans.The steering will come and go while driving the tractor. It is very random and has no particular spot in the turning radius when it tightens up. I can pick the front end of the tractor up off the ground and can turn the steering wheel from left to right with one finger with no drag or tight spots.I checked the fluid level,it is full also very milky looking. I am thinking it was probably left out in the weather sometime during it's life(not now I keep all my stuff in the shed).I have no idea if the fluid and filter have ever been serviced. This is my first tractor with power steering so I am kinda stabbing in the dark at this point. Any suggestions?
fredfromwyo
11-29-2006 19:20:13
 Re: 340 industrial power steering problem in reply to suumoe, 11-29-2006 19:03:16
suumoe, sounds like time for full service, all the oil in the rearparts of the tractor every thing aft of the clutch, There are three drain plugs down under, they need to be taken out and allowed to drain for atleast 12 hours if the oil is anyother than looking like new, and you need to replace the filter. The rearend and hydraulic system take the best of 15 gallons of the correct oil, IH HI TRAN, or suitable substitute, NOT RO 32 46, or68. If you do this I suspect your troubles go away HTH
